Gridtracker and Slicemaster
I use Slicemaster with JTDX.. works great but I would like to use Gridtracker but cant get it to link…it sees my log ok but nor\t JTDX… Does anyone have setups for Gridtracker using Slicemaster and JTFDX ???
    Yes, you can use all at the same time. I'm not in front of a computer, but under reporting, you need to specify the IP address of the computer that Gridtracker is running on and the Port being used. In JTDX you specify the port to send to and in Gridtracker, you specify the port to listen on. They have to be the same number.
