Problem with WSHT-Z V1.48
Mark Griffin
Mark Griffin Member ✭✭✭
edited June 2025 in Third-Party Software
For some unknown reason when I go into WSJT and push the CAT it turns Green. So that is a good thing, but when I push the PTT Button it keys the transmitter but there is no output power. I am using a Flexradio 8400M. It was working yesterday with an earlier version of WSJT-Z but with the new version I cannot make any contacts at all. Please help!
Mark KB3Z
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    DAX on?
  • Mark Griffin
    Yes,
    DAX is on. I did make a contact on 15 meters. And I also check PSKReporter and my signal is getting out just fine.
    Mark Griffin, KB3Z
  • Geoff AB6BT
    Rats! I thought I was on to something.
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    PTT ok but no rf suggests no audio level or attempt to transmit outside band.
    73 Martin AA6E
  • Mark Griffin
    I found the problem. If I would have checked the slice audio, it was on the # 2 instead of 1. Once I changed and updated that, everything was fine.
