Problem with WSHT-Z V1.48
For some unknown reason when I go into WSJT and push the CAT it turns Green. So that is a good thing, but when I push the PTT Button it keys the transmitter but there is no output power. I am using a Flexradio 8400M. It was working yesterday with an earlier version of WSJT-Z but with the new version I cannot make any contacts at all. Please help!
Mark KB3Z
DAX on?
Yes,
DAX is on. I did make a contact on 15 meters. And I also check PSKReporter and my signal is getting out just fine.
Mark Griffin, KB3Z
Rats! I thought I was on to something.
PTT ok but no rf suggests no audio level or attempt to transmit outside band.
73 Martin AA6E
I found the problem. If I would have checked the slice audio, it was on the # 2 instead of 1. Once I changed and updated that, everything was fine.
- 995 Maestro
