Smart SDR Interlock is preventing transmission
Hello I running smart SDR version 3.9.18 and what does this mean " Smart SDR Interlock is preventing transmission" ?
Thank you
    Answer ✓
    I am in a meeting about this at the moment.
    With this exact message (please read it carefully):
    It is informational only and can be safely ignored and we are working on a fix to suppress the message.
    If you get this exact message and you are not able to put the radio into transmit, after you review your settings, then please let us know the details. Mode, band, etc, so we can attempt to recreate it.
    Thanks for your help.
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Hi James,
    This and some other variants of the "Interlock" issue, one or more of which occur apparently randomly during transmission, are known by Flex who is trying to track them down and fix them.
    My experience with this one is it's never actually prevented me from transmitting so I just ignore it. Hopefully they'll have a fix for all of them in the .10 update. The variant that actually prevents transmission is a very serious issue.
    GL Russ KR6W
  • KG5PTE
    KG5PTE Member ✭✭
    Eric Wachsmaann (Admin) in the Flex Radio Enthusiasts Facebook page commented that this interlock message on startup is a bug beeing tracked as SMART-11300 and they are working on a fix. Interesting.
  • KG5PTE
    KG5PTE Member ✭✭
    One more thing, if you turn on your Flex and run it with IOS (Iphone or Ipad) Or with the Maestro I guess you never know that the "Interlock" is not working. As next week. When I travel from Texas to NW FL on Vacation . I leave the Flex 6400 on in the shack. And one PC (With Team-view or Anydesk access) But I do not run smart link on the PC only through the IOS when I want to operate the radio.
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    I have this from time to time.. mostly after Radio has been running a few days straight and I change Bands and when I attempt to TX I get the interlock error. When I check all the TX settings appear ok but i have discovered that just changing TGXL App. from standby to operate will cause the radio/amplifier to stop giving me those errors. Mind you this is on a Band that the Tuner is not required to be operational at all. Works for me every time. :)
  • KG5PTE
    KG5PTE Member ✭✭
    i Get this when I am running SSB Phone mode on 20 meters. And when I boot up the radio every time and with my laptop or desktop PC.
  • Bill AB7AA
    Bill AB7AA Member ✭✭✭
    Mike,
    I hope that this is a clue. When ever I have issues like this I go to the PGXL Settings dropdown box and go Settings>Device Settings, and go to the FlexRadio Tab and just hit Save. It requires no reentries just resave that tab to renew the connection. That always fixes all those connection issues. (for a while anyway).
    Bill AB7AA
