Are there "false positives" on Fan Malfunction?
I have a 6600. Occasionally, I'll get the power button with a single red flash. I know that means Fan Malfunction. In every case, hitting the button allows the Flex to (re)boot. This happens most often when I'm not using the Flex, but sometimes happens when I am using it (predominately FT-8).
Can some sort of power issue cause the Fan Malfunction? Any other external condition that might cause this only occasionally?
Joe
KI5LST
Hi Joe, yes, that can happen. In my case, it showed a fan fault, but it turned out to be a failing SD card. I would do a factory reset after exporting profiles. If that doesn't solve the issue, submit a help desk ticket.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe FAN message is part of a symptom. Sometimes you have to look a bit deeper and see that it might be a DC power issue with the 13.8V not being a full 13.8VDC.
Usually, if it is a FAN issue, the problem is more permanent.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
