Suggestion carry-on lugagge
Unfortunately, the Aurora does not fit in the SKB 2011-7 case that I am currently using for my Juma PA1000+ KX3 combination, so I have to look for an alternative.
Gert,
The Aurora dimensions exceed the carry-on limits so a checked baggage hard case, like Pelican or Nanuk with foam inserts, may be the way to go.
Bill K9GN0 -
There is normally a maximum weight limit of 50 pounds per checked bag as well as a size restriction. The most common maximum size bag allowed is 62 linear (total) inches. A common size bag for checking through is: ~27" x 21" x 14"
Aurora is about 6.74”H (17.1 cm) x 14”W (35.6 cm) x 13.25”D (33.7 cm) so there is lots of room to wrap a case around it. Same size as the 8000's and 6000's and I have carried those on many times.
I prefer not to transport valuable equipment in checked luggage. Taking the Aurora in a case like the SBK 3i 2011-7, as I currently do with my Juma PA1000+ and KX3, will not be possible due to the Aurora's dimensions. A professional carrying bag made of soft yet protective material, similar to those used for photography equipment, seems to be the most likely solution. Unfortunately, my search for a suitable bag with the right dimensions has not yet yielded a satisfactory option.0
If you're looking for a solid case for travel, consider the Pelican Storm iM2600 or the Pelican Air 1535. For reference, an M model radio is about 14" x 14" with a height of around 7.25", which makes for a snug, rattle-free fit. If you're aiming for carry-on size, height is usually the critical dimension to watch.
That said, with a quality hard case, you're generally fine to check it if needed—especially when flying smaller "puddle jumper" aircraft and you have to ramp check it.
In a past life, I traveled with thousands of dollars' worth of electronics in checked Pelican cases and never had a problem. I always carry on camera gear since it's more tempting to thieves, but a black box like an HF radio doesn't usually draw attention.
In the last five years, the only airline that ever made a fuss about carry-on size was Air Canada. Everyone else has been pretty relaxed. I even travel with a 40L backpack that clearly isn’t carry-on compliant, and I’ve never been stopped—especially when heading to hamfests.
Just sharing some personal experience—hope it helps!
Thanks for the suggestion, Mike. The Peli Air 1535 has the same dimensions as the SKB 2011-7 (internal dimensions 20.4 x 11.2 x 7.2") and is therefore too small for the Aurora. Since Flexradio recommends the Aurora as a transceiver for DXpeditions and operators do not want to risk arriving at their DX location without a transceiver, I would advise Flexradio to investigate whether a custom bag can be made available. SPE Expert amplifiers, also widely used in DXpeditions, provide a good example in this regard—they supply their amplifier with a travel bag as standard.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
