DAX fails over time
W2PP
W2PP Member ✭✭✭
I’ve now seen this multiple times. I leave the room and come back say a couple of hours later to find DAX all yellow no streaming. Try to cycle them off and on no good. I have to shut SmartSDR down and then relaunch it to resume streaming.
No one has yet also addressed the issue with stream A refusing to connect with WSJTX via slice master. Yet I can launch WSJTX outside of slice master and operate normally. No other slice behaves this way
Peter
  • Wayne VK4ACN
    Wayne VK4ACN Member ✭✭✭
    Not sure if it's the same problem, but after starting SmartSDR my dax fails after a short time.
    After shutting down dax and restarting it, it seems to be ok then.
    I reinstalled windows11, and then new install of SmartSDR, hard reset of radio and still have the problem. The new 3.9.18 does the same thing. Created a help ticket and they couldn't help. Very annoying problem.
  • Tim K9WX
    Tim K9WX Member ✭✭✭
    For the past month or so, my DAX will fail overnight. I leave the radio and DAX running overnight; when I hit the shack in the morning, DAX is still running but not passing any audio. The little indicator square has changed from blue to yellow. If I close DAX and restart, all is fine. Until the next morning, rinse and repeat.
    I am running 2.12.1.
    Tim K9WX
  • W2PP
    W2PP Member ✭✭✭
    I’ll try just closing DAX.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    A long standing issue with DAX, not fixed in years.
