DAX fails over time
I’ve now seen this multiple times. I leave the room and come back say a couple of hours later to find DAX all yellow no streaming. Try to cycle them off and on no good. I have to shut SmartSDR down and then relaunch it to resume streaming.
No one has yet also addressed the issue with stream A refusing to connect with WSJTX via slice master. Yet I can launch WSJTX outside of slice master and operate normally. No other slice behaves this way
Peter
Not sure if it's the same problem, but after starting SmartSDR my dax fails after a short time.
After shutting down dax and restarting it, it seems to be ok then.
I reinstalled windows11, and then new install of SmartSDR, hard reset of radio and still have the problem. The new 3.9.18 does the same thing. Created a help ticket and they couldn't help. Very annoying problem.
For the past month or so, my DAX will fail overnight. I leave the radio and DAX running overnight; when I hit the shack in the morning, DAX is still running but not passing any audio. The little indicator square has changed from blue to yellow. If I close DAX and restart, all is fine. Until the next morning, rinse and repeat.
I am running 2.12.1.
Tim K9WX
I’ll try just closing DAX.
A long standing issue with DAX, not fixed in years.
- 697 The Flea Market
- 121 Aurora
- 983 Genius Products
