Hardware isolation between RX and Transverter ports?
Birton_N6UG
If I connect the PGXL -60db output to the Rx port, can I also connect a transverter to the transverter port?
I.e. Is there isolation between the 2 ports? I don't want the transverter to see the -60db output.
TIA
Hi Birton, yes, they are separate inputs; the transverter will not be fed the -60 dB PGXL output.
I don't think that the external amp APD works in this version (3.9.18) of SmartSDR. It should be coming soon, however.
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
