Hardware isolation between RX and Transverter ports?
Birton_N6UG
If I connect the PGXL -60db output to the Rx port, can I also connect a transverter to the transverter port?
I.e. Is there isolation between the 2 ports? I don't want the transverter to see the -60db output.
TIA
Hi Birton, yes, they are separate inputs; the transverter will not be fed the -60 dB PGXL output.
I don't think that the external amp APD works in this version (3.9.18) of SmartSDR. It should be coming soon, however.
