Which is correct PGXL or HF Auto
KB4OIF
Good morning. running a 8400M, PGXL, and a HF auto tuner. 27 watts of drive from the flex. SWR 1.2. When TX, PGXL says 550 watts(EXAMPLE) hf auto says 425 watts. running it into a Delta Loop for 40 meters. Which one is correct. 110 Volts house power.
They are all correct. SWR, forward and reflected power are not a constant across a feedline unless it is into a resistive 50 ohm load. If you change the length of the feedline you will see it will change to new values. If you know the SWR on the Antenna side of the tuner it might help explain things a bit more.
Thanks Mike.
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
