New Flex Meter Objects
Mick  W8BE
Mick W8BE Member ✭✭✭
edited May 2025 in SmartSDR API
It looks like Flex added a PA Current and TNF signal Strength meter objects to 3.9. I turned on the meters for PA Current and from the value it would appear I am running 10 Amps even in receive.
I suspect this meter does not work on a 6xxx radio. If it is supposed to then there is a bug as it shows 10 amps regardless of receive / transmit
Best Answers
  • Eric-KE5DTO
    Answer ✓
    This does look like a bug. I took a note and we'll be looking into this. Thanks for reporting. This is being tracked as SMART-11281.
  • Eric-KE5DTO
    Answer ✓
    OK.  I finally have a definitive answer on this issue (SMART-11281, related to SMART-11780).  The PA Current meter that was added was for the FLEX-8000 series, but wasn't marked as such.  Due to this, it shows up for the FLEX-6000 series radios, but has invalid data.  As such, it will be removed from the FLEX-6000 series in a future release.  Our apologies for the confusion this caused.
