New Flex Meter Objects
It looks like Flex added a PA Current and TNF signal Strength meter objects to 3.9. I turned on the meters for PA Current and from the value it would appear I am running 10 Amps even in receive.
I suspect this meter does not work on a 6xxx radio. If it is supposed to then there is a bug as it shows 10 amps regardless of receive / transmit
Best Answers
This does look like a bug. I took a note and we'll be looking into this. Thanks for reporting. This is being tracked as SMART-11281.
OK. I finally have a definitive answer on this issue (SMART-11281, related to SMART-11780). The PA Current meter that was added was for the FLEX-8000 series, but wasn't marked as such. Due to this, it shows up for the FLEX-6000 series radios, but has invalid data. As such, it will be removed from the FLEX-6000 series in a future release. Our apologies for the confusion this caused.
thanks…
Bringing this topic up again in a different context for an 8000 series radio. To compute total watts being used to power the radio, would the formula be:
A) RAD/300/PACURRENT * RAD/344/+13.8
or
B) RAD/300/PACURRENT * RAD/0/+13.8A
or
C) RAD/300/PACURRENT * RAD/0/+13.8B
- 693 The Flea Market
