PTT
albert
Hello,
I'm helping a friend because we're facing a problem we can't seem to resolve. When using wsjt-x, the PTT remains yellow and won't turn blue. It transmits via USB even though it's programmed in DGU. What should I do?
ON5AM
Albert,
What are you referring to when you say 'PTT remain yellow', I know of nothing labeled PTT that is ever yellow.
AL, K0VM
Al,
It's easy with a screenshot.
The modulation is like SSB, which is not normal. I think I checked everything correctly!
Albert,
That is not PTT. That is the DAX GUI TX stream button. The likely cause is that the SSDR Phone/CW panel does not have the DAX button enabled.
AL, K0VM
Now is OK,
Thank you very much Al, it was really a **** oversight.
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 195 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 745 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
