PTT
Hello,
I'm helping a friend because we're facing a problem we can't seem to resolve. When using wsjt-x, the PTT remains yellow and won't turn blue. It transmits via USB even though it's programmed in DGU. What should I do?
ON5AM
  • Al K0VM
    Al K0VM Member ✭✭✭
    Albert,
    What are you referring to when you say 'PTT remain yellow', I know of nothing labeled PTT that is ever yellow.
    AL, K0VM
  • albert
    albert Member ✭✭
    Al,
    It's easy with a screenshot.
    The modulation is like SSB, which is not normal. I think I checked everything correctly!
  • Al K0VM
    Al K0VM Member ✭✭✭
    Albert,
    That is not PTT. That is the DAX GUI TX stream button. The likely cause is that the SSDR Phone/CW panel does not have the DAX button enabled.
    AL, K0VM
  • albert
    albert Member ✭✭
    Now is OK,
    Thank you very much Al, it was really a **** oversight.
