SSDR v3.9.18
I just wanted to say thanks to the entire FRS team for SSDR v3.9.18. If I see anything that may be of help to improve the Smart Signal algorithm I will pass to help desk. A great year for FRS. First Aurora and now 3.9.18. Good deal. Radio updated in less than 3 minutes w/o a hiccup.
73 mike
Also my thanks for the Flex team for the hard work.. Just a warning though, It reset my TX delay to 0. I had it on 40. So people might have to check that .
Hi Wayne, my TX Delay stayed the same on my 6400. Which rig do you have?
Len
8600
I wonder if there is a difference in the 6000 and 8000 series radios here. I just fixed all my CW profiles and they seem to be working now. Did your CW options get reset with the upgrade?
Hi Len,
Skimming through the v3.9 change log it looks like they did some surgery on that area of the code so maybe there's a first-time-through reset required to get initialized again ? Glad its working now.
73 Russ KR6W
Hi Russ, I think you called that one right, it sure acts that way.
Hey Len,
You're a big time Flex guy, do you happen to know if FR addressed the infamous "arbitrary and random interlock" issue in this rev. ? There's some vague language about interlocks in the notes but it doesn't say specifically that I can see. I know they still haven't fixed the incomplete "RF Amplifier Gain setting gets lost" issue because I checked on that. Which is weird because Steve said they fixed over 370 bugs in this revision. I kinda expected all the big hitters to finally get addressed. Maybe not …
Thanks ! Russ KR6W
Hi Russ, no idea… I don't get any insider info, I just help moderate this Community.
Ok Len, thanks. By the way, you do an outstanding job here - thanks very much for that !
73 Russ KR6W
Does anyone knows what is that field on maestro showed up on ver3.9.18?
SSDR shows a lot of signals with, this window is empty. I do not see anything in Release notes.
Sergey, KN7K
Thanks Russ, I really appreciate that!
I upgraded and everything seems to work fine. However, I don't see the Tuner Genius option. I read the release notes and it said I needed to be running firmware version 1.2.17 or above on the TGXL. I am on 1.2.11. However, when I go to download the firmware it says that version is compatible with AG v3 and I am on AG v4? Not sure what to do here.
K4QXX
Burch
Yup, that's been the dilemma all day. Crickets from Flex.
I guess I am alone with that empty extra window on Maestro? Probably will open support ticket.
Sergey, KN7K
Sergey
Im using Maestro A as smart control. With 1 panadapter open, Maestro black screen looks fine and takes up most of the screen like it should. But when I open a second panadapter on SmartSDR, the Smart Control Mode black screen, changes to half and on bottom part looks like a panadapter. I rebooted Maestro, but didnt fix it. Is this what your getting?
Hey Wayne, exactly.
it seems like some bug as it it is not advertise in release notes and this extra screen is empty. I will open support ticket.
Sergey, KN7K
Thanks Sergey
Post here what you find out
I have SmartControl mode display issue as well. But mine is this:
This is with a 6400M. I have tried rebooting, full reset, etc to no avail.
Erik EI4KF
Ditto for Erik's issue. Same screen on 6600M with start of Smart Control and prior to start up of SmartSDR on computer. Once SmartSDR on computer is up and running the screen on the 6600M returns to normal showing the Smart Control box with the controlling SmartSDR device in the drop down section.
But when you close SSDR, the problem reappears.
I received reply from Ken and he pointed to Release notes about Maestro Smart Control (about my issue with 2nd panadapter open and showing extra empty slice B".
"This is a known software defect that the Software Engineers are investigating in more detail.
This issue has been logged as defect number: SMART-11274"
From Release notes:
It does not bother me much as soon as it mostly visual inconvenience as I always have 2 panadapters open.
Hopefully they will fix it soon.
Sergey, KN7K
5 -
At least they’re working on a fix. Still works just a visual annoyance
- 396 Community Topics
- 676 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 327 FLEX-8000 Signature Series
- 985 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 146 Amateur Radio Interests
