Why does my Maestro keep turning itself off
W2PP
W2PP Member ✭✭✭
not only that it appears to crash into off. ??????
  • W2PP
    W2PP Member ✭✭✭
    and the battery is 70 percent charged. It’s sitting perfectly still on a table
    Peter, this is not normal. Please open a support ticket.
  • W2PP
    W2PP Member ✭✭✭
    will do
  • ChrisNia
    ChrisNia Member ✭✭
    I have the same issue with my Maestro, it turns of randomly. just switches off - black screen . Flex 8400 ATU, FW 3.8.23 Maestro on battery with charger connected or without - same effect.
    Hi Chris, same answer - submit a help desk ticket.
  • W2PP
    W2PP Member ✭✭✭
    I have the same issue. Only happens while running on battery. Plug it in a ok. I’m working with Flex currently to sort this out. I’ll post when it’s done
    Peter
  • W2PP
    W2PP Member ✭✭✭
    following up as promised. Bad power module in the Maestro.
  • ChrisNia
    ChrisNia Member ✭✭
    I have the save issue. Maybe 1 time an hour it will turn off by itself….straight to black screen. Any ideas ?
    This is an old thread. If you are having this issue, please open a support ticket.
    https://helpdesk.flexradio.com/hc/en-us/requests/new
  • ChrisNia
    ChrisNia Member ✭✭
    Samr issue here , sent it backto WIMO (EU Flex Dealer)
