Maestro Battery Died
Lorenzo Mendini
in Maestro
Hi, i have Maestro A Version that was unused since 3 years, i have tried some times to restore the battery without a postive result, anyone can suggest me how to replace the tablet battery and if is an operation that i can made myself or it's necessary to send it to a repair center? Please anoyone help me and let me know. Many thanks.
Lorenzo
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI created a support ticket for you. They will update you if it is repairable.
Hi Lorenzo, had the same problem with the Maestro A and it was a **** thing. I opend the Dell Tablet to find out what kind of battery was in there. tHen I ordered from Ebay 3 times the same type of tablet and every one has another mainboard and another battery. That is really ****. You can not find out, what tablet is the same as you have. I ordered exact the same labelled type and it was different. After sevreral times opening my Dell tablet I crashed the display :-(
Now the same problem. Ordered 3 displays for this tablet, but every one is different to mine. So my Maestro A is definitely broken and I put it in a trash. The type A and B are using this Dell Tablet for display and Flexradio can not give any support for this, because of this problems. Tghe new Maestro 3 (C) ist the first, which has a real display with display controller. No longer Dell inside. So I try to buy the new type and hope it works better than the worse A and B types with Dell inside.0
