Software of Maestro A vs Maestro B
Robert Gromen
Member ā
in Maestro
Same software and functionality on A and B.
Hardware & Performance
- Integrated Mini PC: Unlike the Maestro B, which relies on a tablet-based system, the Maestro C incorporates a built-in mini PC. This upgrade delivers faster performance and a more responsive interface. FlexRadio Community
- Enhanced Display: The Maestro C features an 8" touchscreen with improved responsiveness and clarity, providing a better visual experience. FlexRadio Community
š” Connectivity & Interfaces
- Improved Wi-Fi Antenna: The Maestro C boasts a better Wi-Fi antenna, enhancing wireless connectivity and stability. FlexRadio Community
- External HDMI Output: An added HDMI port allows users to connect an external monitor, offering flexibility for larger displays or presentations. FlexRadio Community
- CTIA TRRS Audio Jack: The Maestro C uses a CTIA-style TRRS connector for microphone and audio connections, differing from the separate PTT and mic inputs on the Maestro B. This change may require adapters for certain headsets. FlexRadio Community
š Power & Battery
- New Battery Technology: The Maestro C adopts a new battery system that's globally available, simplifying replacements and ensuring longer operational times. FlexRadio Community
- Charging Convenience: The device charges its battery automatically when plugged into AC power, and the screen displays the current battery level for easy monitoring. FlexRadio Community
šļø User Experience Enhancements
- Responsive Touchscreen: Users have noted the Maestro C's touchscreen as highly responsive, enhancing the overall user interaction. FlexRadio Community
- CW Operation Improvements: The Maestro C provides a local sidetone for CW operations and includes programmable function keys for sending pre-set messages, aiding in efficient communication. FlexRadio Community
These upgrades make the Maestro C a significant step forward from the Maestro B, offering enhanced performance, better connectivity, and a more user-friendly experience.
The evolution of Maestro A > B > C was the result of fact that the Dell tablet that the Maestro was built on was no longer available. B still uses a Dell table but a different tablet configuration. The C no longer uses a Dell tablet but is built around a single board PC with other parts added. The software functionally is intended to be the same.
AL, K0VM
Thank you Mike and Al, greatly appreciate your responses. 73, Robert0
- 388 Community Topics
- 156 SmartSDR+
- 438 SmartSDR for Mac
- 52 Aurora
- 970 Maestro
- 944 Genius Products
