Trying to operate my FLEX-6600 with SPE Expert 1K-FA
johna8119
I have used this combination for several years now, but after disconnecting and reconnecting the 6600 for an SD card replacement, I can't get the amp to transmit when I key the xcvr. (Yes, I do have the amp in operate mode.)
I have Dan Tassel's cable between the devices, with the USB and TX1 connectors appropriately positioned. But I can't remember the other rear connections. Specifically, where does the Relay connector on the back of the amp connect to the 6600?
Tnx. John W4KV
So I referred back to a previous post of mine. I simply needed to check the bands for which I wanted the xcvr to key the amp. I do have the cables properly connected. Maybe the new SD card deleted the Tx Profile info?
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
