Flexradio 8600M and MacBook with WSJTX
Best Answers
The easiest way to run any FT8 and FT4 is to use macssdr from Marcus.. can be downloaded from apple app store..does cost about $99 …search app store for "smart sdr"
Marcus version of smartsdr includes integrated FT4/FT8 and rtty modes and cw decoder as well a log and clusters …well worth the price for first time flex and mac users
Running mac native wsjtx with 8600m front panel slices is not easy but YOU can run wsjtx and smartsdr but will need loopback to route audio (aka dax data steam)
Search the community and you will find lotsa info on how to do this…
i run multiple macs (macbook air M1. mac minis M1) all running current macos 15.4.1
I run a flex 6600m with mac and wsjtx and other support apps ( xdax.xcat, loopback).
i did have 8600m but encountered difficulty interfacing wsjtx using these supports apps on a mac.
Paul K3SF
hi andreas
here are two loopback devices to use with macssdr
i tend to create specific loopback devices rather than general ones…i find easier to debug
and
to include new digital s/w
the top device is wsjtx xmit..take audio fromn wsjtx and send to macssdr fro transmit
the next device is how to get audio from macssdr to wsjtx fro receive decoding
this is wsjtx configuration/setup
these are loopback setup for using macssdr with my 6600m on macbook air M1
these example should be clear enough to easily read and understand.
I hope ;-)
this should allow you to run wsjtx with macssdr ..so you can run super fox , or Fox/hound mode of FT8 that macssdr does not currently have available.
Paul K3SF
Hi Paul, thanks for your feedback. I have now SmartSDR from Markus as well loopback but i need help for the configuration of loopback.
Could you tell me the correct configuration from loopback to route what is needed?
BR
Andreas0
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
