No Transmit tone heard when using Smart SDR V. 3.8.23
If your referring to CW Side tone and if your running remote away from the Radio then YES there is NO side tone as it is sent on the local radio Speakers, This is one of the draw backs to running CW remote but there are a couple ways around this, One is the "WinKeyer", a Computer Software Program/with a RS-232 Port to connect the Key to, and the other is to build a "MORCONI" which for me the MORCONI which uses a TEENSY 4.1 with Ethernet Micro Computer, and a hand full of parts or you can buy one pre-built is the BEST way to go because you can customize it as much as you want, these will generate a side tone locally and the MORCONI can have 8 memories and works with several different smart Keyers or straight Keys.
Here is a Link to the information on building a MORCONI here on the FLEX mail site.
73 and hope this helps
Bret WX7Y
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
