6500+6600 on same network, one has no sound remotely Details in body
6500+6600 on same network, both newest 3.whatever.
Locally all is good from desktop PC
Port forwarding / UPNP configured for both radios as per threads here.
Portable PC connecting via Tmobile Home Internet connection to be "remote" for testing, and I can see and control both radios
I cannot HEAR audio from the 6500. 6600 is normal and fine.
Same portable via local wifi and both are good for control and audio.
Any ideas as to why one wouldnt pass audio?
THanks,
Steve
KS3RO
Hi Steve
I run 4 radios on the same network, all using uPNP in the router, so it should 'just work'.
On the FLEX-6500, which doesn't work, does it pass the SmartLink test and do you get the Green Icon?
Yes, both pass the smartlink test with green icon.
Sooo, changed the 6500 ports to a new number and it works.
It (either my network, or smartlink config or the aliens) doesnt like 25555 as a port.
Changed it to something in the 24k numbers like the 6600 was were good to go.
The green test light worked both ways.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
