Can the GPS antenna with the 8600 be perm mounted outside?
Gear is in the garage with no windows. I may be able to mount it outside on top of my SPG box just outside the garage.
Is this ok?
Thank you. Setting things up one item at a time. Just finished setting up the AG.
Greg
AB7R
    Hi Greg, have you tried it inside yet? It may or may not work there, but if it locks OK, you may be fine with it in the garage.
    I don't know what moisture and dust ratings the GPS antenna has, but if I were to put it outside, I think I would put it in a weatherproof box.
  • AB7R
    AB7R Member ✭✭
    Thanks Len. I managed to stretch the antenna to a window in the garage door and seems to lock OK.
    Radio arrived a couple days ago so just trying to get it all setup and configured.
    Very cool, enjoy your new rig!
