Diversity Topology
I have a question regarding an 8600 and diversity reception.
Currently my configuration is 8600 (Ant A) —> PGXL (Drive A)—> TGXL 1x3 (TX).
I have one of the tuner outputs connected to a three-position manual switch to select between one of three antennas. The other two are for dedicated antennas.
I'm looking for suggestions regarding diversity reception and what I need to modify in my current setup.
Thanks.
    Hi Geoff, for diversity reception, you will need an antenna on your ANT2 or RXB port.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hi Len, I understand that is what is necessary.
    I'll just have to figure the best way to add more switching as I don't have any antennas dedicated for receiving.
    Right now with the manual switch I'll need an additional switch to move one of the antennas to another port on the radio.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    or set up an antenna exclusively for receiving. I use a loop on ground on the tx input. No switching needed since it cannot be used to transmit.
  • John KB4DU
    Err, should be rx antenna (auto corrupt again).
  • Geoff AB6BT
    John…do you find the loop on the ground beneficial for diversity reception?
  • John KB4DU
    I have not. I use it as a low noise antenna, similar to a Beverage, which I don’t have room for.
  • Geoff AB6BT
    edited April 22
    Thanks John.
    I'm looking into a LoG or loop as possibilities for a receive antenna. So I appreciate your feedback.
    Diversity is something new to me.
