WSJT-X monitor
Roger
Roger Member ✭✭
edited April 2025 in Third-Party Software
Just aquired a FLEX 8400M with which I am still getting aquainted !!
Qustion 1/ Running SmartSDR 3.8.23 and WSJT-X.
All working well EXCEPT I cannot monitor outgoing audio even with MON on.
Qustion 2/ Whilst running SmartSDR, how do I get A and B horizontally on screen?
Thanks Roger G0IUW
  • Erik Carling EI4KF
    Q2 - if you mean
    press the left most icon in the bottom bar which will open a second (B) slice.
    Q1 - monitor is on and the level is set approx mid-point in the scale?
    you should hear your transmission
    Erik
  • Roger
    Roger Member ✭✭
    Thank You Erik..
    Understood
    The monitor issue I managed to solve by updating WSJT-X to a later version
    Again thanks for the info
    Roger G0IUW
