WSJT-X monitor
Roger
Just aquired a FLEX 8400M with which I am still getting aquainted !!
Qustion 1/ Running SmartSDR 3.8.23 and WSJT-X.
All working well EXCEPT I cannot monitor outgoing audio even with MON on.
Qustion 2/ Whilst running SmartSDR, how do I get A and B horizontally on screen?
Thanks Roger G0IUW
Q2 - if you mean
press the left most icon in the bottom bar which will open a second (B) slice.
Q1 - monitor is on and the level is set approx mid-point in the scale?
you should hear your transmission
Erik
Thank You Erik..
Understood
The monitor issue I managed to solve by updating WSJT-X to a later version
Again thanks for the info
Roger G0IUW
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
