10 Mhz Reference Out
This is my 1st time using a GPDSO. I have verified the GPDSO is locked and the 10 MHz Reference signal is locked on the GPDSO as well. I decided to hook my oscilloscope to the 10MHz Reference out and look for the signal. I am using a 50 ohm bnc cable about 3' long. I found I don't see any signal at all on the port.
I assumed I would be able to see the reference clock output signal. I tested the setup using my Elecraft signal generator and had no issues seeing the 40 meter reference signal
I am curious to know if any one else has measured the 10Mhz reference signal out source.
Regards
I think you need the optional Flex GPSDO unit installed in your 8600 to see anything at the 10M ref output port.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe 10Mhz connector is only installed if the GPSDO is installed.
Guys, I know you want to help. Apparently you did not read…
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
