GPSDO option with FLEX-8600 any problems?
using WSJT-X WSPR mode is off FREQ by 1HZ 80MTRS to as much as 7HZ on 10MTRS. It appears after the 8600 is on in excess of 12HRS it settles down. But the same thing happens next time its turned on. Have had the 6500, 6600 both spot on frequency after GPSDO locks up. I think this is a different GPSDO in 8600.
Can you post a screen shot of the GPSDO screen please. What is the ppb part?
GM Mike TKS, FYI the Radio Setup, GPS Tab - UTC time is not in sync with the bottom right of the FLEX 8600 display. I have the screen shot here but see no way to add it to this post.0
Let me suggest or note the procedure I use to capture a screen shot and then post to an email or this window. Open the Radio Setup, Select GPS or wherever you screen is. Be sure that that screen is selected and "in front" of all others. Press ALT and Print Screen at the same time….. Then go to the Leave a Comment section and Press CNTRL and "V" at the same time…. Here is mine using those steps.
Won't work for me, TNX anyway.0
Disregard my query, I have opened a ticket with the help desk. TKS Steve/n6kog0
OK. Let them know it is a GNSS not a GPSDO and include the screen shot.
TKS Mike, but that's not my screen shot. I do have the GPSDO installed in my 8600, but for what ever reason, I can't do a screen shot on this dell cpu. By the normal "Press ALT & Print" then go to this box & hit "Ctrl & V". I use the "SNIP" to get a screen shot, but can't put it here.0
The GPSDO on my 8600 never worked. The latest info about it is
Tim Ellison (FlexRadio HelpDesk)
Feb 17, 2025, 8:12 AM CST
Deroy,
I wanted to provide you with an update on your current RMA. What we discovered testing your unit is the issue, which presented itself as a hardware problem, is actually a firmware issue designated as SMART-10785. We have also determined the root cause of the problem. It has been addressed in the upcoming SmartSDR v3.9 firmware release. Once you install the SmartSDR v3.9 firmware, it will restore the 10 MHz GPSDO output...."
So it is broken at least until SmartSDR v3.9 firmware release.0 -
Ned K1NJ
8600 with GPSDO says 28 seen 9-15 being used. However no lock.
Blue light in Version 3.8.23 is ON. A message in Radio Setup says:
"GPS is installed. Frequency error correction is not".
TCXO is the only 10 MHz option that seems to be usable. An external
10 MHz source that was used by my 6600 is not recognized when connected.
Error when attempting to use GPSDO is 3Hz at 15 MHz WWV. TCXO is good.
Radio arrived this morning. Hope I'm missing something.
Any ideas would be welcome.
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 123 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 698 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 922 Third-Party Software
