6600: Can I describe what is connected to ANT1 and ANT2 and pass to log?
KW1M
Still learning this 6600 -- did a forum search w/no luck...
6600+HRD+WSJT-X+GridTracker2
2 antennas - ANT1=Cushcraft R8 and ANT2=B&W dipole
Possible to pass which antenna is in use for a contact? Ideal would at least pass ANT1/ANT2 to log; better to replace ANT1 with a user-defined value (R8); same for ANT2.
Thanks! KW1M
Thanks! KW1M
Not really without writing some sort of application to read the status of the radio.
Interesting idea though.
Thanks Mike -- I was tjhinking a tab on radio setup so SDR has a reference point to look up.0
The Flex Application Programming Interface (API) has all of the information that you would need for that purpose, no additional tabs are necessary.
As Mike said, an app would be needed. If you have programming experience, this would not be a difficult app to write if HRD has an API of its own.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
