TGXL 1X3 WITH PGXL AND K4
Considering a 1x3 TGXL. I only have 2 antennas. Using a K4 exciter. How do I change antennas? Is it manually done on the screen or some software setup?
In addition I have a PGXL.
There is a Windows application or you can feed the CAT output from the K4 to the TGXL using Kenwood CAT format which I think the K4 can send.
Cat from K4 to PG XL.
In TG XL setup, you enable Genius Integration for PG XL and use the pulldown menu to select the PG XL by its serial number. This requires PG XL and TG XL to be connected to same LAN. The PC can use the PG and TG utilities.
Antenna selection can be done manually from tuner or app, or it will use last used antenna for that band when band changing.
To share K4 CAT port between TG XL and other apps/hardware, you can purchase and use Win4K4 program which has built in CAT port splitting.
73 Dave wo2x
Presale Support
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
