6500 Startup: Calibration, Timeout, LED Flashes three times rapidly
Found some old reports to remove power. Removed power. Applied power and I am not operational.
SHOULD I DO ANYTHING MORE ?
Radio SN: 2117-5332-6500-1279
Region USA
HW Version: v3.8.23.35640
Model FLEX-6500
Nickname A161753320019
Using SmartSDR v3.8.23 on Windows 11
    Hi Bob, I would submit a help desk ticket.
  • Hi Len KD0RC - THANK YOU for your comment. I have submitted a Help Desk Ticket. 73, Bob
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    If the 3 flashes are red, this likely identifies a 'boot failure' which may be a failing SD card.
    Fortunately, Flex Help Desk is really good at diagnosing, sending out a new card and installation is a snap.
  • Case Closed. I submitted a Help Desk ticket. I got a prompt response and followed the procedure carefully including wait times. I am now 100% operational after making a few QSO's, shutting down, and restarting. Subsequently did some more contacts with success.
    I'm glad to hear that you got it going again Bob!
  • Val  DM1TX
    Val DM1TX Member ✭✭
    I want ot comment but Len was faster. I had same issue and was easy solved by replacing the card with a new one. Still love my 6500 :-)
    DM1TX
