SO2R mode: can't toggle stereo
I'm running SO2R with a Maestro A controlling a Flex 8600, and running N1MM.
All the SO2R functionality seems to be working fine, with the exception of toggling stereo (with the tilde/backtick key) so that I can hear both slices at the same time.
I've run SO2R in the past with two separate radios and SO2R hardware, and toggling worked fine in that setup.
What might I be missing in my configuration?
I'm not sure if it's a problem with my N1MM configuration, or my Maestro configuration.
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    Have you got OTRSP set-up in SmartCAT?
    Create a port that matches the one in N1MM.
  • N1CFO
    N1CFO Member
    edited March 2025
    Thanks Rich. Yes, I have OTRSP set up in SmartCAT, with:
    -Slices: A/B
    -Process: N1MMLogger
    -Serial: COM11
    In N1MM, I have COM11 configured with the checkbox "CW/Other", and in the "set" dialog box, I have:
    -Radio Nr: Both
    -Two radio protocol: OTRSP
    And in case it's relevant:
    In the "Logger+ Audio Setup" I have the following items selected in the dropdowns:
    -SO2R: Single soundcard L/R
    -DAX Audio TX
    (I also tried using "SO2R: Two soundcards mono", but that didn't seem to make a difference.)
    Don't forget to check use "Internal Radio Codec". that isn't your problem, but I thought I would mention it.
    Are you sure your ` key is actually a ` (backtick) ?
    Could there be another program intercepting it?
    this is what I have:
  • N1CFO
    N1CFO Member
    You are right! On our team's computer, AutoHotkey was used to map backtick to another function. Thanks so much for the suggestion!
    Excellent…. Glad that helped. And, yes, I have been burned by something similar more than once.
