SO2R mode: can't toggle stereo
N1CFO
Member ✭
I'm running SO2R with a Maestro A controlling a Flex 8600, and running N1MM.
All the SO2R functionality seems to be working fine, with the exception of toggling stereo (with the tilde/backtick key) so that I can hear both slices at the same time.
I've run SO2R in the past with two separate radios and SO2R hardware, and toggling worked fine in that setup.
What might I be missing in my configuration?
I'm not sure if it's a problem with my N1MM configuration, or my Maestro configuration.
Have you got OTRSP set-up in SmartCAT?
Create a port that matches the one in N1MM.
Thanks Rich. Yes, I have OTRSP set up in SmartCAT, with:
-Slices: A/B
-Process: N1MMLogger
-Serial: COM11
In N1MM, I have COM11 configured with the checkbox "CW/Other", and in the "set" dialog box, I have:
-Radio Nr: Both
-Two radio protocol: OTRSP
And in case it's relevant:
In the "Logger+ Audio Setup" I have the following items selected in the dropdowns:
-SO2R: Single soundcard L/R
-DAX Audio TX
(I also tried using "SO2R: Two soundcards mono", but that didn't seem to make a difference.)0 -
Don't forget to check use "Internal Radio Codec". that isn't your problem, but I thought I would mention it.
Are you sure your ` key is actually a ` (backtick) ?
Could there be another program intercepting it?
this is what I have:
You are right! On our team's computer, AutoHotkey was used to map backtick to another function. Thanks so much for the suggestion!0
Excellent…. Glad that helped. And, yes, I have been burned by something similar more than once.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
