GPS no longer working on flex8400
Tried disconnecting the antenna and powering off the radio for 5 min. Did not fix the problem.
Suggestions?
Greg N7RDJ
Without further information as to the antenna placement like ground floor, basement, etc., repositioning the antenna was the first logical thing to do. I had similar experience with my antenna in the drop ceiling in basement near an outside wall. No windows nearby. It only took moving it about 6" or so, then bingo.
There was an error rendering this rich post.
Similar issue here immediately after my upgrade to v3.10.10 I have the GPS antenna outside on a bracket on my tower so it has a decently clear LOS to much of the sky and it had been working prior to my upgrade however the operation has always been characteristically slow when acquiring satellites. There isn't much in the way of diagnostics to help confirm what might be wrong for instance if the antenna is an active design they could confirm connectivity and basic operation by measuring current draw but instead there are no satellites visible etc… Just a continuous yellow light so anyone else seeing issues?
Please open a support ticket.
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
