Picket post reception
KE7FD
KE7FD Member ✭✭
edited March 2025 in SmartSDR for Windows
Mine is a recent install of a 8400 running 3.8.21 on Win11. Everything works, I was able to hold side band and FT8 contacts just recently. However, I noticed from the first day that I got things running, there is a rapid clipping of the reception, you can hear it just like "picket posts" then goes away for several minutes before returning. It's visible on the waterfall and audible in the PC speakers. Since I'm seeing it on the Flex I'm assuming the problem originates there and not the PC because the PC gets its audio feed from the Flex. It occurs regardless of SSB or wsjt-x. Another forum thinks it's because my PC is using Wi-Fi, but as I've said, the PC is after the fact.
Thoughts?
Glen KE7FD
