flexcontrol not working; 8400 3.8.21
KE7FD
KE7FD Member ✭✭
edited February 2025 in FlexControl
I can plug/unplug/plug it in and see it in Windows 11 Device Manager. I used it on my 6400 just fine but now, no joy. I got it to work once but the frequency adjust resolution was pitifully slow, so I know it was working, ever so briefly.
Any thoughts?
Glen KE7FD
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    Go into device manager and move the flex control to com 99. Reboot everything and then find it in settings and see if that fixes it.
  • KE7FD
    KE7FD Member ✭✭
    edited March 2025
    Actually tech support had me move it off of the hub and directly to the PC and it works now. However, I'll try your suggestion because it'd be nice to have the hub working.
  • DM2DZM
    DM2DZM Member ✭✭
    Hi, I now have a similar problem with 8400M and Flexcontrol. I have changed the COM to a 5, this is also shown as serial USB in the device manager but when I open SDR it does not work. I can also change the COMN but it does not start either.
    Does anyone else have any good advice please?
    73 de Peter DM2DZM
