Turf file for EU
I recently purchased a second hand Flex 6600, but the Radio does not cover 5Mhz TX. Where can I obtain the appropriate turf file?
73, Charlie GI4FUE
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Best bet is to create a Help Desk Ticket. The staff will then guide you through the process of them developing a TURF file for your radio and then how to install it.
  • gi4fue
    gi4fue Member ✭✭
    Thanks Don
    I'll do that
    73, Charlie GI4FUE
    Are you sure it doesn't cover 60M?
    Are you transmit settings correct? If you exceed the legal bandwidth, then the radio will not go into TX.
    As a start, make sure you LPF on the TX Settings are less than 3000hz. This is a very common error.
  • VE7ATJ_Don
    Hi Mike… I suspect that the UK allocation is different from the 'channelized' set in the US — hence the need for a different TURF file. This is from the RSGB website:
    UK radios are shipped with the correct Turf file. First, we need to confirm it isn't a operator configuration issue.
    This can be confirmed in the Radio Setup menu where it displays what region is loaded.
  • VE7ATJ_Don
    So Charlie… if Help Desk has not already asked..
    What do you see on the Radio Setup tab under Settings? on the top right, there is a Region: label. What does it say beside that?
  • Vidas
    Vidas Member
    My 6700 was shipped from Austin to EU with USA Region TURF file.
    Where I have to ask for the right one?
    Hi Vidas, submit a help desk ticket and Flex Support will be able to help.
  • Mr Radio
    Mr Radio Member ✭✭✭
    Remember to provide your radio's serial number when contacting Flex Support. TURF file which you will receive can only be used with your radio.
    Tom
