Turf file for EU
I recently purchased a second hand Flex 6600, but the Radio does not cover 5Mhz TX. Where can I obtain the appropriate turf file?
73, Charlie GI4FUE
Best bet is to create a Help Desk Ticket. The staff will then guide you through the process of them developing a TURF file for your radio and then how to install it.
Thanks Don
I'll do that
73, Charlie GI4FUE
Are you sure it doesn't cover 60M?
Are you transmit settings correct? If you exceed the legal bandwidth, then the radio will not go into TX.
As a start, make sure you LPF on the TX Settings are less than 3000hz. This is a very common error.
Hi Mike… I suspect that the UK allocation is different from the 'channelized' set in the US — hence the need for a different TURF file. This is from the RSGB website:
UK radios are shipped with the correct Turf file. First, we need to confirm it isn't a operator configuration issue.
This can be confirmed in the Radio Setup menu where it displays what region is loaded.
So Charlie… if Help Desk has not already asked..
What do you see on the Radio Setup tab under Settings? on the top right, there is a Region: label. What does it say beside that?
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
