v3.7.4 and the 8400
I think I know the answer, but I'll ask it anyway. Will v3.7.4 run on an 8400? I may try it for for grins.
DO NOT load any version older than 3.8.21 in an 8400 or 8600. I do not know if the radio would allow downgrade or not but 3.8.21 is the first version to support the new hardware. Remember, the CPU and FPGA are different than 6000 series radios.
73 Dave wo2x
Hi Ed, the 8000 series require a minimum of 3.8.x.
I know. I was hoping someone would pipe up and say… Yeah! I did it and it works fine! ;-)
The word and in stricken out? Really?
Hi Ed, you misspelled and. I corrected it.
Haha that's not the only thing!
Follow up question. Will trying it brick the rig?
Thanks Dave!
It may not brick the radio. But, you may well experience problems because of how the firmware for the new radios is written. It is always a good idea to run the recommended version for your radio. I certainly wouldn't suggest trying that on a expensive radio I just purchased.
I do not know what will happen but during Alpha testing, we were told explicitly to not use an older version than 3.8.21.
73 Dave wo2x
It won't likely let you even try. But, if you feel lucky, give it a shot! :)
Considering the luck I had changing the plastic overlays on my 6600M, I think I'll pass. :-)
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 195 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 745 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
