SO2R RTTY DAX ONLY STREAMS A MAESTRO TO 6600M
Wondering if it is me or the way the Maestro is configured? Anyway I have two instances of MTTY running but audio only streams to A. An error message appears for slice B, yellow light, no streaming. DAX is depressed for both slice/VFO A&B, split display, seems to be correctly configured. I do not use any other non-FLEX programs other than N1MM, like STREAM DECK, STREAM BUTTONS, STREAM THIS, STREAM THAT (just making those up). Can anyone help with what I am missing or the order in which I am setting up the radio. Thanks.
Do you have a DAX rx channel set-up for slice B?
Each slice has needs a DAX rx channel, on slice B click on the DAX drop down and make sure that you assign a channel - usually channel 2 if you have slice A assigned to channel 1.
The DAX button you press to turn on or off is for DAX TX, not RX.
Rich
Thank you. I use the Maestro. Your reply seems to show an SDR software solution. How is this changed or integrated for Maestro use???
It's the same, on the Maestro you should have the DAX menu still on each slice? Press on the frequency so you see the menu then change the DAX number.
Below here it says 1 for Slice A, on Slice B make sure this is on 2 etc.
In other words, using a MAESTRO, how does one "assign" a DAX channel to a RX slice, ie "B"????
Use your finger to press on the frequency on slice B and the screen you see above will show, where it says DAX press on that and then choose 2.
Thank you!! I have it and all working properly!!
- 349 Community Topics
- 613 The Flea Market
- 7.9K Software
- 2 SmartSDR+
- 6.3K SmartSDR for Windows
- 411 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 205 FLEX-8000 Signature Series
- 920 Maestro
- 893 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 138 Contesting
- 754 Peripherals & Station Integration
- 973 Third-Party Software
