Why when I key the FHM-3 mic, whether the PGXL is active or not, there is no RF output.
Setup is an 8600M downstairs and a Maestro upstairs where I operate remotely the rig. I get no RF output when I key the FHM-3, which is the current mic profile, while when I am in CW mode the rig produces RF as it should. Any help would be greatly appreciated.
David, K1MT
I just noticed that when I select the Default FHM-3 Mic option the mic input M-HDST can not be selected. My understanding is the with the Maestro that is the only option and this the input on back of the Maestro that the FHM-3 is plugged into.
Are you using Flex’s Y cable adapter between the FHM-3 and the Marstro C?
Yes, and the issue I had was that multiFLEX was enabled in the menu of the Maestro. Thanks for the inquiry.
David, K1MT
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
