Why when I key the FHM-3 mic, whether the PGXL is active or not, there is no RF output.
David43
David43 Member ✭✭
Setup is an 8600M downstairs and a Maestro upstairs where I operate remotely the rig. I get no RF output when I key the FHM-3, which is the current mic profile, while when I am in CW mode the rig produces RF as it should. Any help would be greatly appreciated.
David, K1MT
  • David43
    David43 Member ✭✭
    I just noticed that when I select the Default FHM-3 Mic option the mic input M-HDST can not be selected. My understanding is the with the Maestro that is the only option and this the input on back of the Maestro that the FHM-3 is plugged into.
  • Neil D Friedman N3DF
    Are you using Flex’s Y cable adapter between the FHM-3 and the Marstro C?
  • David43
    David43 Member ✭✭
    Yes, and the issue I had was that multiFLEX was enabled in the menu of the Maestro. Thanks for the inquiry.
    David, K1MT
