strange happenings with SmartSDR 3.8.21
This has happened twice. The Tune button and MOX button will gray out for no reason. The setting on the radio when it greyed out were 20M did hour run on FT8 and then changed mode from DIGIU to USB and it greyed out. MY TGXL says no antenna is present.
I'm currently setup in 2SOR so I can monitor 6m all the time. My voltage is 13.94 temperature of the radio is 92.7 I rebooted the radio after 3 minutes of downtime. This strange when the radio came up it was still greyed out, I change bands to 6m and the Tune and MOX button came back to life. So I'm puzzled in what it could be
It seems to tied to DIGU and changing back to USB
My software version is 3.8.21.34850
Jim
WU5E
Hi Jim, can you post a screenshot of SmartSDR when this happens? There is likely a reason for this behavior. Also, check your TX Band Settings screen to be sure that PTT Inhibit has not been set due to a fault of some sort (high SWR, etc).
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
