6400M with CW Skimmer / Slice Master
I am trying to help a friend get CW Skimmer working with a 6400M. It has been along time since I set it up and as I recalled at the time I used the softrock radio and DAX IQ. I can not get DAX IQ to work with the M model. It seems I have to run SmartSDR on the local PC running CW Skimmer. I watched a couple videos but did not see any config settings for CW Skimmer. If some one can point me to a document that covers the 6400M + CW Skimmer + Slice Master it would be appreciated.
I got it working.
You might find the integration with SDC Skimmer a bit easier and it has a number of other features.
Thanks Mike, I tried it 1st but had the settings wrong on CW Skimmer. It had been about 4 years since I used CW Skimmer. I will give it a go.
Regards
Hello, unfortunately, I also had some problems when installing 3.10.10 on the FLEX 8400M, but now it's working. The Slicemaster also works, but it no longer starts the CW Skimmer, which always worked fine before. Does anyone have any ideas?
73 de Peter
CW Skimmer is broken and FlexRadio has a fix for it in the next version.
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
