V3.8.21 bug
Trucker
Trucker Member ✭✭✭✭
edited January 2025 in SmartSDR for Windows
Just experienced the "SmartSDR has lost connection with the radio " bug again. I had the front panel of my 6600M going as well as SmartSDR on my Windows pc. I had noticed that some local interference had popped up on 40 meters. So,I clicked on the WNB that has always handled the interference well. This time, both the front panel and my pc's display froze up and showed a pop-up box stating that SmartSDR had lost the connection with the radio. I may just roll back to v3.8.20 as I hadn't had this particular problem with it. Maybe v3.9.x wlll clear this bugg up and hopefully, not introduce something else not expected!
    Please open a support ticket for this.
  • Trucker
    Trucker Member ✭✭✭✭
    Mike, I will once I find a way to repeat the problem. As it is, it occurs at very random times making it difficult to reproduce reliably. I had posted about this on another forum and was told it was a known bug and should be fixed in 3.9.x.
  • Trucker
    Trucker Member ✭✭✭✭
    Problem reappeared today. So, I gave in and rolled back to v3.8.19 ( was plenty stable for me previously). So far, after a full reset and cold boot, everything is working like it should. I will let it cook for a couple of days and see if everything continues to work correctly.
