Uploading contacts from my IOS (v 7.0.43) to QRZ
I thought that a work-a-round would be to simply delete the old adi file on my iPod after uploading to QRZ but since I'm an IOS newbie, I can't find the apple equivilent of "file manger."
go to the app "Files" then select "On My iPhone". Then look for the file folder "SmartSDR". Inside it, you will find the log file (file ending in .adi) Press and hold on that file, the select Delete. Then you can go back in the app and download your updated file to that directory.
Note: if you have icloud enabled there is a different location.
Again, go to go to the app "Files" then select "iCloud Drive". Then look for the file folder "SmartSDR". Inside it, you will find the log file (file ending in .adi) Press and hold on that file, the select Delete. Then you can go back in the app and download your updated file to that directory.
I use an app called Ham-Toolbox (created by the same developer) to manage the logbook file. You can setup linking to LOTW, QRZ, ClubLog, and eQSL in it. Then it will do pushes and pulls of updates to all of them. Very handy and saves a lot of time. I have the logbook directory in my WSJTX setup to go to that logbook in my icloud drive. Then when i work anyone on the app, on my pc with wsjtx, or other means, they all are always up to sync with one another. This adif is also used to manage my alerts on JTAlert. Give it a try. You will be glad you did.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
