ios two radios
My friend can connect to my 6400 from his Iphone ok. I tried to connect to my 6600 on my Iphone at the same time .6600 was not on LAN .Did not work . I can use 6600 at the same time when on LAN. Port forwarding on both is different. I am aware of Multiplex but this is two different radios.
I am more curios than looking for solutions.. paul, wa3qpx
does each radio 6400 and 6600 have different id /pswd for smartlink
…i beleive each radio should have its own ID and pswd for smartlink
Paul K3SF
The way it works is that you can have multiple radios connected to the same SmartLink account even if they are at the same location (network).
Based on what Paul, wa3qpx is saying, it sounds like your iPhone wasn't on the same network if it can't see the radio. This can happen on some WiFi networks including using a MESH network if it is not setup in Bridge (or Access Point) mode.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
