FHM-3 HANDSET HOW TO HOOK MAESTRO C ****?
HAVE THE Y-CABLE HAVE THE FHM-3 AND MAESTRO C The document that Mike VA3MW dId not dump enough for me. The Elbow connector on the handset plugs into (BLANK) with the phono adapter plug into (blank) then plug the y-cable plugs into maestro at the (blank)
don't laugh at me or make bad comments I have been blown up in combat so many time its hard to comprehend documents sometimes
Jim
WU5E
Hi Jim, the Y cable male end plugs into the lower left hand jack labeled HDST (next to the external power jack).
The mic elbow connector plugs into the Y cable labeled as TRS Mic.
I think that you also need a 1/8 inch mono male plug to RCA female adapter to plug the RCA PTT plug into (on the FHM-3 cable). That adapter plugs into the PTT jack just above the HDST jack.
yep just ordered the TRS cables because in Infint wisdom flex don't include when ordered and spend 2,400 my two cents.
Jim
WU5E
762-353-3375
Hi Jim
I replied to the other post with details on how to connect the stock FHM-3 to the Maestro C.
73 Dave wo2x
a picture is worth , here is the cable that came with my Maestro C
Hi James
the 3.5 mm male plug on end of FHM-3 mic cable that came with radio plugs into the jack on Y cable with picture of a mic. Optionally, you can plug a pair of headphones into the jack on Y cable with picture of headphones.
The Y cable kit should have included an RCA female to 3.5 mm male mono adapter. Plug the RCA male from mic cable to adapter then into the PTT jack on Maestro
73 Dave wo2x0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 36 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
