SUB D
N5NHJ
Member ✭✭✭
in SmartSDR API
Based on to the API Wiki, the command SUB D should dump a list of actual subscriptions.
I always get a malformed command error:
C101|sub d
R101|50000016|
What am I doing wrong?
Hi Max, I was unaware of this command. I don't see it in the wiki…
In any event, try sub d all
I tried it and it does not give the error, but I don't see what it does.
EDIT: Aha…
S28380B20|stream 0x20000000 type=dax_iq daxiq_channel=1 pan=0x40000000 daxiq_rate=48000 client_handle=0x02559FE9 active=1 ip=192.168.0.24 S28380B20|radio daxiq_capacity=16 daxiq_available=14
S28380B20|stream 0x20000001 type=dax_iq daxiq_channel=2 pan=0x0 daxiq_rate=48000 client_handle=0x02559FE9 active=1 ip=192.168.0.24
S28380B20|radio daxiq_capacity=16 daxiq_available=14It gives the same result as sub daxiq all
Hi Max, I did some more poking around and see that sub d is a SmartSDR command line API command. I don't know how to start SmartSDR as a command line app, so maybe someone can chime in on that.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
